So I have a buddy from school that is in the process of dropping a 96 Ranger. He has a lot of experience with that sort of thing but not so much with fiberglass and interior work. So I decided I am helping him out.
Each door will house a 6.5" component set. Probably Alpine Type R.
On with the pics
Here is the door panel
Time to start hacking it up...
Getting an idea of how the new piece I am adding will fit...
I Have to keep the spot for the door handle and the window crank
Same from side to side via flush trim bit...
Sticky tape is how I made the copies...
Flawless reverse mount speaker rings...
NOT THE SPEAKER, but a demo of how it'll look
-Mark
Host of "CarAudioFabrication" - YouTube Car Audio Tutorial Channel
Check out my forum section here on SMD for my builds and tutorial videos!
Subscribe on YouTube: http://www.youtube.com/CarAudioFabrication
Pieces mounted together
Started foaming..
Perfectly symmetrical
This will have a plexiglass insert
The top mdf piece, and the surround of the plexi insert will be black vinyl. The body filler part grey twede as well as betwen the plexi insert and the speaker pod. The speaker pod will be painted the same color as the truck.
-Mark
Made the plexi inserts today, here is a little tutorial
First gather your materials:
  • Router and router table
  • Scissors
  • Flush Trim Bit
  • 3M Double Side Sticky Tape
  • Plexi Glass
  • Wooden replica of insert Shape
Here is the flush trim router bit, note the bearing on top which rides the curve while the bottom does the cutting
Put your double side tape on the template, this allows you to stick the template to the plexi glass thus preventing it from moving.
Adjust your height of the router bit in order so that the bearing rides on what you want to copy.
Looks good. You will note I left the protective covering on, this is important as it prevent scratches from appearing on the glass. (The blue tape is because the edge was pealing.)
Begin cutting the plexi
When you are done simply remove burrs with a lite file (If there are even any I had none). And separate the template from the plexi insert
Nice clean edge
Fits great!
-Mark
Mounted the rings, here is how to do it perfect...
Added some cardboard for a mounting base...
Coil some paper up so it fits inside the rings and tape it
Now place your ring at the angle you want
Inscribe a line around the ring, now remove the tape and lay the paper flat
Transfer this to another piece as a copy
Here you can see they are the same and mirror copies
-Mark
Measure them out and mount em to the board using hot glue
Now mount your rings using hot glue initially, then some CA or super glue
Do the same for tweeter rings
Looks great!
There you go guys, hopefully they will be wrapped soon
-Mark
Pods all glassed
Nice and semetrical
Checking the fit
Added some body filler
Here is where the handle is to pull the door shut
Some final filler work and holes cut for tweeters
Comming along great, I am jealous they wont be mine! :(
-Mark
looks sick bro cant wait for finished pics .... good work ....
~Matthew
1998 Toyota Camry XLE V6 3L
(1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm
with Shock and Proximity
(1) 20% Tint All Around (Gately Audio)
(1) 250 Amperage HO Alternator
(1) Big 3 Done In 1/0
(2) Kinetik HC2400 Power Cell
(1) Alpine IVA-D106 Receiver
(1) Peripheral Video Bypass Device
(4) Alpine SPS-17C2 Speakers
(1) Alpine KCE-422i iPod Control Interface
(4) Sheets Dynamat Extreme; for speakers
(1) 10 Square Feet Hushmat (Trunk & Rear Deck)
(4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils
(1) Wall Built By David, Tuned to 32 Hz
(1) Rockford Fosgate T40001bd Amplifier
(1) Stinger 1/0 Wiring (2 runs of + 2 runs of -)
(1) Stinger Volt Meter
