Nobody knows it because it's different with every setup. Hell flipping my box over gives me a totally different peak.
Build your box, cover the port up and run a sweep 40-80hz through it with a termlab. Then use the numeric data display to see the exact peak.
Although even this doesn't work exactly because your peak will change as your SPL increases... the only way to find it properly is just test, test, test.
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 1800 Guests (See full list)
