i need help with my wiring i'm running 2500 watt amps,a basic battery up front and a kinetic in the back,i was gonna do 4 runs of 4 guage or 2 guage,2 positive and 2 negative but i'm not sure how i do it,i've seen steve doin it but i'm not sure,i know one goes to a fuse block then runs to the back,do i do 2 off the battery or 1 off the battery and 2 off the block?and with the grounds do i ground one in the back by the batterys and the other to the - on the kinetic?and i do 2 runs of + to my amps off the backbatterys and have 3 differnt grounds,one for each amp and one  for the back battery?i believe thats right just wanna make sure
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
front stage:id ctx65cs
dc power 270 alt
lots of kicker 1/0
just do two runs of 1/0 gauge and that should be efficient enough vs 4ga or 2 ga
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
can i get away with doin 4 guage though,im not tryin to cut corners but i got alot of 4 guage,and when i ground my back battery to the chassis can i ground both my amps to the battery or do i have to have seperate chassis grounds for them
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
dc power 270 alt
lots of kicker 1/0
well if i do o the 4 runs of 1/0 guage is my wiring for the batteries right?positive to positive negative to negative and the positive off the back battery i can run two 4 guages off for my amps right?
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
dc power 270 alt
lots of kicker 1/0
  • Who's Online   0 Members, 0 Anonymous, 685 Guests (See full list)
