Bills Posted August 1, 2008 Report Posted August 1, 2008 Hey, I'm looking to get two of these guys for my 2 DC LVL 4's and i was questioning if they do rated power at 1 ohm. i'm going to be running 2 Kinetik HC2400s, a 200 amp alt, an MLA mod, and all 1/0 wiring. i will have either a red or yellow top optima up front also. but yes. does this amp do rated power.... if not, about how much will it be pumping out? thanks, Bills Quote KwB Team DC Audio Midwest captain
RamenNoodles Posted August 1, 2008 Report Posted August 1, 2008 Some of the lower end Hifonics amps have been said to not run full rated power. Expect around 2k-2300 rms. If you are getting two of them, that will be more than enough to run a lv4. Quote Diablo Audio Technologies Fi Car Audio Ascendant Audio
Bills Posted August 1, 2008 Author Report Posted August 1, 2008 ok, well ya. i'm looking to run an spl/ daily driver setup...... bigger box, more power. better elecrtical. bigger port. ya. my current setup did 145.1 sealed on the dash wit a 44hz tone. i'm looking to gain one or two more DB. think this may do the trick? Bills Quote KwB Team DC Audio Midwest captain
RamenNoodles Posted August 1, 2008 Report Posted August 1, 2008 You did that with two of the Crunch GP1500s? And yes, you will be adding around 1k rms to each of the subs. Just be careful with that much power to a 1k rms sub. Quote Diablo Audio Technologies Fi Car Audio Ascendant Audio
Bills Posted August 1, 2008 Author Report Posted August 1, 2008 ya. with the box being 6 cubes and 4 aeroports tuned to 35 HZ Bills PS, if it is too risky to run that much power to them, i'll get a smaller amp, liek the BXI2008. but i'm only going to go full tilt when i burp at comps. Quote KwB Team DC Audio Midwest captain
dmanson Posted August 1, 2008 Report Posted August 1, 2008 man stick with the 2608ds and do two runs of 1/0 Quote 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
RamenNoodles Posted August 1, 2008 Report Posted August 1, 2008 You will be fine with those 2600s, just dont go gain crazy. Quote Diablo Audio Technologies Fi Car Audio Ascendant Audio
Bills Posted August 1, 2008 Author Report Posted August 1, 2008 man stick with the 2608ds and do two runs of 1/0 Two runs as in one for power, and one for ground? or just two power? caus i have one run of +and one run of - already Bills Quote KwB Team DC Audio Midwest captain
Bills Posted August 1, 2008 Author Report Posted August 1, 2008 bump Bills Quote KwB Team DC Audio Midwest captain
dmanson Posted August 2, 2008 Report Posted August 2, 2008 Two runs as in one for power, and one for ground? or just two power? caus i have one run of +and one run of - alreadydo another run of + ............ you might have to do the same with the - ............... anyways regardless don't starve the amps. you'll be pushing over 4300rms and 1/0 is normally good for around 3500rms Bills Quote 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
