jonnylowkon Posted August 4, 2008 Report Posted August 4, 2008 ok so i finally figured out im going with 2 18 fi ssd's instead of 4 12's .. now i called around and found someone that would attempt this size of a box for a short 2 door yukon for the rear cago area .. i have a total of 14 cubes to work with and ill be running one amp to each sub so ... 1. should the subs be in one common volume since two amps will be used or two seprate boxes 2. what type and size, length , depth should the port be for tuning the subs to fi specs of 33hz in either the single dual 18 box or for 2 single 18 box the box area size im workin with is 48 width 20 height 30 depth and the subs will be faced upward along with the ports unless there is another way thanx in adavnce for any help guys this site rocks! 250 amp mechman alt Sundown 100.4D Sundown 1500v2 now goin to the cruze Sundown ZV3 12d2 Sundown sa6.5cs X2 Kenwood X597 Trying something new 2011 Chevy Cruze X8 1500v2
ficaraudio789 Posted August 4, 2008 Report Posted August 4, 2008 ok so i finally figured out im going with 2 18 fi ssd's instead of 4 12's .. now i called around and found someone that would attempt this size of a box for a short 2 door yukon for the rear cago area .. i have a total of 14 cubes to work with and ill be running one amp to each sub so ...1. should the subs be in one common volume since two amps will be used or two seprate boxes 2. what type and size, length , depth should the port be for tuning the subs to fi specs of 33hz in either the single dual 18 box or for 2 single 18 box the box area size im workin with is 48 width 20 height 30 depth and the subs will be faced upward along with the ports unless there is another way thanx in adavnce for any help guys this site rocks! what i was thinking is subs up port back message me on myspace again I AM GAY. MY FATHERS COCK IS IN MY ASS RIGHT NOW! "I talk shit from the safety of my house"
jonnylowkon Posted August 4, 2008 Author Report Posted August 4, 2008 bumpity 250 amp mechman alt Sundown 100.4D Sundown 1500v2 now goin to the cruze Sundown ZV3 12d2 Sundown sa6.5cs X2 Kenwood X597 Trying something new 2011 Chevy Cruze X8 1500v2
Toxiccasper Posted August 5, 2008 Report Posted August 5, 2008 about 14 square inches of port per cubic foot of the box and go with two chambers
