and BTW
wtf is a Skag???
you said its 7ohms with a multi meter with the crossover all hooked up to the mids, woofers, and tweeter?
or just estimated what the impedance would be
Also on the caps, are any of them Radial caps?
meaning 1 way only- DC caps? that would do it
what are the impedances of the inductors? again, that also matters
for tweeters you usually want a very low resistance inductor, like 0.1- 0.5ohms, and the inductance needs to be very low as well
crossovers can be pretty tricky
1 last thing that I DO SEE
That non Poly cap is only rated at 100volts, what are the poly caps rated at?
Try to kee all caps somewhere in the 200v-400v range just so all the components match, and keep that as a poly cap as well
and double check how that 1 resitor is wired up, its possible it can be wired is series when supposed to be parr, or viseversa, very easy to mess that up
those few things can be way easily overlooked, and cause the impedance to drop below the recievers abilty to play pretty asily if just 1 wire is backwards
Thats with everything hooked up,
Here is what im going off of:
http://www.partsexpress.com/projectshowcas...a/crossover.jpg
try this,
disconnect 1 woofer, and re measure everything
check total impedance of the circuit
if higher than 4/6ohms, go ahead and re test
if it still does it, disconnect whole woofer crossover portion
check impedance, if over say 4/6ohms, retest
if it still does it, put the woofer leads back together as it was
midrange, disconect midrange circuit
test if still a realistic impedance, go ahead and retest
still does it, patch it back up, and do the same for the tweeter
doing that will allow you to pin point Exactly where the crossover is shorting out at
Iam assuming either resistor, non poly cap not being up to par compared to rest of xover, or a crossed wire that was over looked
when I said 4/6ohms, i really meant anything that wont kill the reciever/amp over 4 ohms on almost anyamp will be fine temporarily
I have a Harman Kardon 35wx5 rms high current reciever from 97' Ive had it that whole time, and I have used this thing as a tester amp for many years, 1ohm subwoofers, multi speaker arrays, but I have ran it down to 1ohm many times, and even right now I hae it ran daily at 3ohms per right left, and 6 ohms for the center, and I push that thing hard as hell, and I still get flawless sound from it
but again, its a HK High current reciever
dont deal with a prefab, well, if you want to learn how to build crossovers I mean
if you can care less, Iam sure that Xover will be fine
I rather build my own, you do need patience with them, but the knowledge you learn goes beyond just crossover design, it can open your brain to alot of other ideas
how did you like trying to get than bandpass 12db filter right?
thinking about it, it may be at the bandpass filter where a possible misswire happend, they can get confusing
try this,
Alright im gonna go check it out. Its weird its like it can play all day at 40db but when i turn it up to 35 it shuts off. If this xover is fucked up then its cheaper to buy the prefabbed one lol i have already invested way to much money in this project haha.
alright then.....
guess that works too
make sure the impedance, and xover slopes and #s are pretty close, dont have to be 100% accurate, but pretty close anyways
