Days like you described, cloudy, muggy, dark.....even good MEKP will take awhile to cure the resin.
If you hadn't already, use some heat from a lamp or a heat gun and et it to start kicking. Don't concentrate the heat in 1 spot for too long or heat the whole thing up too much. Once it has some heat to it, the resin will start to kick and it will cure.
Another option is to mix up just enough resin and MEKP to cover the project. Except add double the MEKP. When it heats up during curing, it will cause a chain reaction to start the underlying resin to cure also.
Disclaimer::: Too much MEKP will get very hot. Smoke. Sometimes catch fire. Be aware of how much you add.
Building The Best.....Repairing The Rest
The bitter after-taste of a poor quality job will last far longer
than the sweetness of that cheap price!
