Amp Wont Turn On?
Beanz
Well, usually, lights on amps are controlled by the remote so we can rul that out.
Did you check the voltages at the terminals?
well the lights on the front dont turn on fully like the lights will be dim and then the power light wont even turn on.and idk since i dont have a multimeter.
maybe a melted fuse holder up front.
we cheked the fuse on the front and the fuse isnt popped and the fuseholder looks all good too.but like melted like it's all gone?
Invest the $7 into a multi-meter they are your best friend.
That, or stick your tongue across the terminals. (Disclaimer: DON'T!)
is it those ones that tell you all the info like ohms and amps and all that sruff?
Yes, but don't use it to measure the amps your amp is pulling.
It is only rated for 10 amps.
And If you measure current, make sure to follow directions, place the meter in series with the load NOT parallel.
so what would i use in order to make sure the amp is working?by finding current??
okay ill get one tomorrow and see what it says and ill tell you guys tomorrow.
  • Who's Online   1 Member, 0 Anonymous, 1670 Guests (See full list)
