alright well right now iv got my btl on a 600watt amp and its Very loud and iv got a 4000watt amp ill be putting on it once i get it reconed(it needs new tinsels leads so it cant take very much power) and I just dont see how it could any louder... I put a 2400watt amp on it and turned it up the the bass got kinda muffled so whats that mean??
~REFS~
-CA.com-Gianotti(2 18" FI BTL D1) Slowd N Throwd(Wiring),Ebrunn(PC monitor),Rab(HK4000D)
-SMD.com-Nismofreak(Radar),BigP(Phone Headset),anonymous(Xbox360 Headset)
/bump
~REFS~
its probably distorting alot. turn the gains down and bass boost on everything off. on the gains, if you dont have a multi-meter, put the volume on your headunit to 3/4th volume, play a 60hz 0db tone (get from RoE) and turn the gain up on the amp until the sub sounds a tiny bit distorted, then turn it down a little bit then your set.
if you DO have a DMM use this graph to help you
my hpf and lfp on my amp are off so is bass boost only iv got bass boost turned up on my stereo
~REFS~
Turn your low pass on omg
its got a switch with lfp,hfp, and full and iv got it on lfp so now i need to turn the lfp knob up?
~REFS~
put the lpf to around 60hz. turn ALL BASS BOOST/LOUD FUNCTIONS OFF. have bass boost knob all the way down on amp. your distorting the shit out of that sub. if you have a sub sonic filter on the amp, put that to 30hz
alright ill give that a try thnx for your help
~REFS~
  • Who's Online   0 Members, 0 Anonymous, 483 Guests (See full list)
