ok well i built a enclosure for my 15 BL, and the port has wicked bad noise.
heres the demensions of the enclosure.
width- 35
hiegth- 13.5
length of top- 18
lenght of bottom- 24
can someone help me make a port to fit that, so it will be tuned to 35 hrtz? if so it would be appretiated. i need help asap though cuz i have to go finish the project today. thanks in advanced.
Man there are alot of things that can cause port noise.
If you can post pics it might help out alot.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
Posted (edited)
u have wicked port noise because you have no specific tune frequency since ur port is at an angle if i remember the box....
this might be causing alot of turbulence which is why i said when u were making the box aeroports would help since they could be put in the box at the angle of the front baffle
port noise is caused by turbulence or not enough port area... so pics and more info will help
this is the one i helped you with right?
u prolly notice it doesnt sound as loud as it should either since there is alot of wasted energy making port noise
u could be loosing 3db easy... which is the same as giving ur bl half the power you are now in the right enclosure
Edited by decafcappucino
no i had no measurements at all the measurements up there i came up with. ill get pics but im not proud of it cuz we had to throw it together kinda quickly i have a comp monday or tuesday...and i need this done...ill get pics tho.
whats the port width... port length
did you round over port entrance/exit
anytime you have a port on an angle it will not give favorable results...not unless you use max port surface area
heres the way i think of it:
when a slot port is at an angle and trying to produce 35hz... and the box is tuned to 32hz.... but its only tuned to 32hz at the longest length or in ur case the bottom of the box... so it almost like u shrunk the port surface area on each note because only a small portion of the entire port is tuned to a set frequency/can play a set freq
so the bottom of the port might be tuned to 32, but the top could be tuned to 35-36hz... and the higher the tuning the higher the port surface area needs to be to sound correct
to put it another way...
would you use 3 4" aeroports for a box....but have each port a different length/tuning, no
cause you wouldnt have a defined tune freq... this method doesnt work for a ported box and it is the problem u are running into with ur slot port
ok well i have a ?. im just gonna make a new box..fuck the one thats in there...if i made one with a slot port and not angled. could i have the slot port firing towards the car n the sub pointed up? if so...i used RE calc for a enclosure....dont know how accurate it is...but i need a box asap so its better than nuttin.
let me jump in and ask a question what if you do have the dimension of the ported box and specs of the sub still yet how do u tune the port
Cmogreenz
2 alpine 1242d
sony h/u
boston acoustics front/rears
xt2000d usamps
alpine mrpf250
4 awg stinger wires
