DUBIE Posted September 20, 2008 Report Share Posted September 20, 2008 (edited) yesterday i was driving going to go pick my my lil sisters and couzins then out of nowhere the (2)amps just turned off...plus i dont think the amps shouldnt turned of even if a had it turned really loud.....i had it to 15 - 35...(volume)..could it be maybe remote?..i dont think rca's might be the problems,maybe battery?.low voltage?.....could anybody help me out here...?.. Edited September 20, 2008 by DUBIE Quote Link to comment Share on other sites More sharing options...
DUBIE Posted September 20, 2008 Author Report Share Posted September 20, 2008 anybody?!?! Quote Link to comment Share on other sites More sharing options...
Beanz Posted September 20, 2008 Report Share Posted September 20, 2008 is there a protect light on for the amps? Quote That's why they don't deliver. Yer ass better go sit along the side of the road and wait. You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do. Link to comment Share on other sites More sharing options...
Blue Posted September 20, 2008 Report Share Posted September 20, 2008 If i was in this situation i would do this: 1. Check all the fusses, including the power wire if that checks out and still doesnt work 2. i would check to make sure all the connects are good that checks out and still doesnt work 3. make sure the remote turn on is working and if that doesnt do the job, then i have no idea. Quote formerly known as Blue86f150 its a 4th order just because its tuned in the 40z doesnt mean it wont reach down and jiggle your balls at sub 30 hz frequencies. Regardless if they were dipped platinum and were stuffed in Beyonce's twat.....way too fucking exspensive this sux camel dicks Link to comment Share on other sites More sharing options...
DUBIE Posted September 20, 2008 Author Report Share Posted September 20, 2008 (edited) is there a protect light on for the amps? yea..on both amps.(green = on)(red = protect mode).but right now everything works.it was only yesterday that my amps turned off or shuted down....but anyways when the amps turned off or shuted down..i couldnt see them beause there wired at my trunk...so yea..but then after like 5 mins later when i was still driving i left the HU still on then mins lata the music came back on again...like amps turned on again...i dont know what might the problem be..maybe the amps were HOT?..or i dont know right now... Edited September 20, 2008 by DUBIE Quote Link to comment Share on other sites More sharing options...
Blue Posted September 20, 2008 Report Share Posted September 20, 2008 that might of been the problem. if it happens again, pull over and check the amps to see if they are hot or not. Quote formerly known as Blue86f150 its a 4th order just because its tuned in the 40z doesnt mean it wont reach down and jiggle your balls at sub 30 hz frequencies. Regardless if they were dipped platinum and were stuffed in Beyonce's twat.....way too fucking exspensive this sux camel dicks Link to comment Share on other sites More sharing options...
Beanz Posted September 20, 2008 Report Share Posted September 20, 2008 how do you have the subs at waht ohms?and is that amp a 2 channel amp or a mono block? Quote That's why they don't deliver. Yer ass better go sit along the side of the road and wait. You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do. Link to comment Share on other sites More sharing options...
DUBIE Posted September 20, 2008 Author Report Share Posted September 20, 2008 how do you have the subs at waht ohms?and is that amp a 2 channel amp or a mono block? i have one "12" mtx 4500 brigded to the 2 channel amp...and the other amp is a 4 channel amp for mids and highs...but the amp for the mids and highs shouldnt shuted off because they dont pull out as much juice than the one that has the sub... Quote Link to comment Share on other sites More sharing options...
Beanz Posted September 20, 2008 Report Share Posted September 20, 2008 do you have them both running on the same power wire? Quote That's why they don't deliver. Yer ass better go sit along the side of the road and wait. You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do. Link to comment Share on other sites More sharing options...
DUBIE Posted September 21, 2008 Author Report Share Posted September 21, 2008 do you have them both running on the same power wire? naw.each amp has it own power wire,remote,ground, and RCAS... Quote Link to comment Share on other sites More sharing options...
