15inch Ma Audio Ma1500xl Dual Box Plans
well I cant build a ported box because i need some trunk space so if someone can hook me up with some plans that would be great
here are some specs of the subs http://www.autoaccessorystore.com/home_n.a...ail&id=1659
forget what i said bout my thoughts that was earlier. build it so I still have some trunk space minimze as much as possible. Maybe ductape can help gain
1995 Ford Mustang 3.8l V6 5 Speed
Plans:
  • 2 12 inch dc Level 4s
  • DC 2.0k Amp
  • KCA 1/0 Power Amplifier Installation Kit
  • 220 Amp Alt
  • XS Power 12V D925 AGM Battery
  • Stinger Volt Gauge
  • Rockford Fosgate RCAs
  • Box built from birch. Probably tuned to 32 Hz
  • 0 gauge wiring for extra battery
  • Dynamat
“I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.”
Al McGuire
“The only mystery in life is why the kamikaze pilots wore helmets”
Al McGuire
remember this always
Close only counts in horseshoes and hand grenades
bump
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
wow no help whatever
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
I'm no expert but... I'll run it through BassBoxPro and post the optimal enclosure (according to it). I'll post one for higher output, and if you want one for a flatter frequency response.
Here it is:
It's 1" MDF with a double baffle making the front be 2" thick, sealed boxes need to be as strong as possible, also be sure to use glue along with the screws during assembly and to run either some silicon or extra glue along all the seams on the inside to stop the possibilities of air escaping. Also be sure to seal very well around where the wire exits so there isn't an air leak there either.
Edited by lunari
Getting loud on a budget. Impossible? We shall see!
95 Chevy Blazer
Pioneer DEH-6700MP
RF T10001BD
AA Havoc 18"
  • Who's Online   1 Member, 0 Anonymous, 473 Guests (See full list)
