Battery Charger Question. Please Help
i borrowed a schumacher battery charger that can can do
10 or 20 amp fast charge
2 amp slow charge
75 amp engine start.
it says its compatible with agm batteries.
can i charge my kinetik battery under the hood even though its wired parallel to the back batteries? (4 batts in total)
and it says on the manual that i must connect positive to positive post and negative to the vehicles ground. the cable is too short for it to reach the frame. can't i just connect it to the negative terminal?
my negative terminal is grounded to the frame of the vehicle with 0 gauge wire.
thanks for the help!
2 amp slow charge
i've got a schumacher 10 amp charger ........ got a optima underhood and kinetik in the back and hell i charge them in parallel with no problem. just let it sit for 5+ hours to make it they are charged. when i charage it hook the clamps up to the underhood batteries + and - ...... no problems so far.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
yup, a ground is a ground. if possible, i would put the least amount of charge on for a longer period of time, instead of pushing alot, quickly. its better for the battery in the long run..
Wasted, Incorporated
Up Front: Optima Yellowtop
HU:Pioneer Avic N1 w/ 2007 upgrade
Front Stage: MB Quart 6.5 comps
Rear Fill: Infinity Reference
Sub Stage: RE MT 18
Sub Amp: Undecided
Sub Enclosure: 5.5 cubes tuned to 33hz
Absolute Terminals
SkyTec 5100RS 2-Way LCD Pager
KnuKonceptz Wire
My Build Log
  • Who's Online   0 Members, 0 Anonymous, 979 Guests (See full list)
