Fi Car Audio
I HAVE TO SSD 15 WITH A ROCKFORD FOSGATE T10001BD ON EACH I GOT ONE OF THE AMPS FROM HIGH DESERT AUDIO FOR ABOUT 250
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
1 optima yellow top (rear)
1 xs power 5100r (front)
big 3 and 1 run 1/0 stinger wire
my build
my rebuild
Since your on a budget heres the best amp you can find
http://www.sonicelectronix.com/item_12211_...+BXi+1608D.html
If you get the amp above get both subs d1ohm so you can get a decent 1 ohm load.
Whats your max. price?
What options for subs?
Your gonna have buy a 2nd Batt. & Upgrade your electrical system. But you should'nt need to buy a alternator. (Heres a cheap batt. Kinetik Rocks!!)
http://www.sonicelectronix.com/item_8531_Kinetik+HC+800.html
What kinda car is it going in?
Enclosure ported or sealed (I recomended ported)
If ported and space is'nt an option build to 8 cuft. tuned to 34hz. That would be best.
But if that was me I'll get the enclosure (Maximun Slam)
http://www.decware.com/whorn.htm
I wonder if my old Alpine Type E tens would work?
i thought i read somewhere here that Fi subs were rated at either .75 or 1.50 ohms
is that true?
and another noob question
if you were running subs parallel how do you connect the wires?
Bass is my drug. One hit and i was hooked.
is that true?
anyone?
