that jbl will be plenty for the BL, just make sure you tune your gains correctly with a multimeter.
look for 1000rms on it at 2 ohms, and use 12 gauge speaker wire.
with the subwoofer, use 10 gauge wire. because that will support 2400rms at 2 ohms (iirc). thin wire can only support so much voltage and current.
sorry i mean 10 gauge
after the amp its ac, higher voltage current. 12g is waaaaay more than enough for that amp (the box says 1200rms@4ohm and 1500rms@2ohm), 12g speaker wire is fine for the speaker connection, but because of the 160amp draw that it has, youre going to need 0g run to the back, and then a distro block/stepdown/extra batt to step down to 4g for the terminals
and honestly, a btl is only the way to go if you have the cubic footage and amperage it needs, if you cant put up the power and space, going a step down is almost always louder and cleaner.
Team DC
and i use like 4 gauge wire? "with the amp" or maybe bigger??
Edited by GORILLAslap
starting fresh, chrysler 300.. no subs amp nothin
I NEED HELP looking to purchase saz-1500d and 15" 1000rms subREFS- feedback/refs.. click!
use 1/0 for your power wire potna ..... that way if you add a lil more power later you wont have to redo everything. 1/0 will take you around 3500rms but anything lower than 3500 is okay.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
use the biggest wire you can fit in your amp. if that amp does 1200rms at 4 ohms then use 12 gauge yea your fine.
12 gauge: ~21.8 amperes
8 ohms - <3800 watts
6 ohms - <2850 watts
4 ohms - <1900 watts
3 ohms - <1425 watts
2 ohms - <950 watts
1 ohm - <475 watts
the Dual 2 option on Fi's site will make it to 4 ohms.
  • Who's Online   0 Members, 0 Anonymous, 2073 Guests (See full list)
