Forceww Posted October 22, 2008 Report Posted October 22, 2008 I was wondering if anybody on here has benched an American Bass 400.1 on 16v. Im looking for power output especially at 2, 1, and .5 ohms and lower. Thanks for any help guys! **New setup in the works** Shocker sigs ftw! *Breakin Glass and Kickin Ass* Team SBC Team Full Force Refs SMD-derrick, Bangin Explorer, Exposport, Bass 14 CA-connersdad19 x2, Ridnclean, Deafdreamz, nismos14 cac.org-Spl Guru, Andrew, dblover, lunari
Boon Posted October 23, 2008 Report Posted October 23, 2008 I have only done mine at 12v (only thing I had the current available to test with ) They pull about 3600w @ 12v @ 1 ohm and just under 4kw @ 0.5 ohms and make hardly any more (~4150?) @ 0.25 ohms, not worth the risk unless your box rise is epic. A fair estimation would be to go off what Cactus Sounds says about their 5kw as it's almost identical inside... 12v 1 ohm 3400w 14.4v 1 ohm 5000w 16v 1 ohm 5900w 18v 1 ohm 7500w They scale very nicely with more voltage 10.x volts fo' life!
Forceww Posted October 23, 2008 Author Report Posted October 23, 2008 I have only done mine at 12v (only thing I had the current available to test with )They pull about 3600w @ 12v @ 1 ohm and just under 4kw @ 0.5 ohms and make hardly any more (~4150?) @ 0.25 ohms, not worth the risk unless your box rise is epic. A fair estimation would be to go off what Cactus Sounds says about their 5kw as it's almost identical inside... 12v 1 ohm 3400w 14.4v 1 ohm 5000w 16v 1 ohm 5900w 18v 1 ohm 7500w They scale very nicely with more voltage id have to say im likin those numbers **New setup in the works** Shocker sigs ftw! *Breakin Glass and Kickin Ass* Team SBC Team Full Force Refs SMD-derrick, Bangin Explorer, Exposport, Bass 14 CA-connersdad19 x2, Ridnclean, Deafdreamz, nismos14 cac.org-Spl Guru, Andrew, dblover, lunari
mazda6i07 Posted October 24, 2008 Report Posted October 24, 2008 Those numbers look great for that amp.
