ok..today i bought an amp from a friend of mine (crunch PZI.250.2) so well i installed it on the car just to test it out....by the way i had 8 gauge wiring for my other amp i have in there so anyways i installed it wired it to a '12' mtx 4500 and someother 10's i had laying around there...so i bridged all three woofers togethere..i believe thats total of 1 ohm load?...so anyways i turn on the car turn the music up 16-35(volume)...and i see lights dim a lil...so i turned it up a lil more 25-35(volume)...then wow light were dimming alot..also the RPM went a lil more lower than normal.i believe voltage drop...it sounded loud! but i see ima need alot of upgrades...
what size power wire would i need?
what size of fuse?. right now i have 100 amp anl fuses here..would that work?.
would i need extra battery(s).?
definitely BIG III..1/0 gauge wiring..
am i missing anything?..
and what good woofer would i need for this (crunch PZI.250.2)?..i was thinking on a '15' power acoustik mofo..
i would take any advise from anybody..!
Edited by DUBIE
i wouldent run that amp at one ohm since it is a two channel amp which can only get down to 2 ohms you may end up damaning the amp with that one ohm.
here's the stats on the amp
RMS Power Range : 250-500 Watts
Number Of Channels: 2
Maximum Power: 1000 Watts
Built In Crossovers: Yes
Channel Separation: Yes
That's why they don't deliver.
Yer ass better go sit along the side of the road and wait.
You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start :D
I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do.
i didnt really see the info on the amp....but right now im not gonna use it till i get all the stuff i need...but when i get everything how do you wired it at 2 ohms?
isnt this the stats of the amp?or just the rms wattage?
RMS @ 4-Ohms: 250W x 2-Ch
RMS @ 2-Ohms: 500W x 2-Ch
RMS @ 4-Ohms: 1000W x 1-Ch
Edited by DUBIE
what subs do you plan on using with that amp.
it's the rms i think.
like i said ^^^^^ i was thinking on a '15 power acoustik mofo..that should be enough power for it?.or am i gonna need more?
2 (30amp) fuses..
just making sure .when most of those were made they mistakenly had 2 40s.ive ran that amp @4 ohms mono before and had ok power,but id run it on one woofer.
American Bass*DC Power
it will push it but not that well,youll have to run that amp at full tilt and without the power to let that amp run in that manner it will clip=burnt voice coils.but you need a dual 2 ohm or single 4 ohm woofa
  • Who's Online   0 Members, 0 Anonymous, 929 Guests (See full list)
