i was thinking of wiring up a battery in the back of my truck. b/c i have to wire up two amps and one takes 0 guage and the other takes 4 gauge. would a second battery be best or how would i wire up both to the one battery? i am a big idiot from time to time and can think of anything. so thanks for the help
still a big noob
Live Fast Die Fun!!!!
Use it or lose it
still a big noob
just wire (+)from front battery with (+)to back battery and (-)from front and (-) to back...and if you had extra more battery(s) later do the same thing with them...
you don't have to run a - all the way up front. just ground it like you ground your amp. unless you have money for another run of wire.
Need any thing chromed? Hit me up!!!
gamer tag: (360)
mEmEnToMoRi64
My Myspace
refs:
from here: RollinSoLow, Derrick824, Ray
from c.a.c.o. : teamsubgopoof, splvictim20, SundownAudioNY
from C.A.J. : Donpisto, spladdict19, CAJunkyard, JBLCAMRY, DasBot (robot underground)
from ca.com: alxmlr789,photocrazy8
oh yeah my bad brotha!..i forgot about that...half awake overhere!..yea what ^^^^ he said...keep in mind keep your ground as short as possible...
but then would the battery keep the amp on the whole time or would it shut off when i turn the truck off?
Use it or lose it
You don't need any distro blocks.. Your back batter pretty much is a distro block... Wires off back batt to amp.. Don't matter what guage..
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
Your remote wire turns your amp on/off... Not your batterys
Passport Build Here
if you get a battery with the bolt type posts, this is super easy
run 0g from front + to back battery, use a ring terminal to the bolt, from the same bolt, run wires to your amps, with whatever gauge wire and ring terminal they require.
run a 0g ground from the negative terminal to the chassis, and then using the same guages and ring terminals, run ground lines to the amps.
basically front batt to reaar, and rear to amps, so u have 3 terminals stacked on the bolt, and then chassis to neg, and then to neg of amps, so there is again, 3 stacked on the one bolt.
Team DC
  • Who's Online   0 Members, 0 Anonymous, 1011 Guests (See full list)
