Speedo And Other Backlights Are Not Working
i got a 1999 alero 4cyl and i installed the sub liek a a week before this problem occured i was thinking that its a loose connection but i cant find it
at night i cant see the speedometer cause the backlights wont turn on, nor will the backlights at the shifter to put it in drive or the heat and cooling switches
i checked every single fuse and relay i searched all of google nadddaa
the problem happened after i hit the turn signal a little too hard
1996 deville on 18" full face rims
-2 gauge wire.
-a2400db
-RE SE-X in a 4ftc box tuned to 32hz
-tview touch double din
-rockford punch 6x9s(rear)
-mtx 6.5(front)
front and rear stage will soon be changed build log will start as soon as it aint cold!
relays were all good liek the speedometer works jsut i cant see it at night cause tehre is no light
-2 gauge wire.
-a2400db
-mtx 6.5(front)
how would the harness affect the lights? jsut wondering never occured to me
-2 gauge wire.
-a2400db
-mtx 6.5(front)
It didnt only effect the lights but the interious lights and HU wouldnt turn on. the door locks locked after the keys were turned off (yea the posessed ass car locked us in)
Im pretty sure some of the wires were backwards in the HU cuz a shop fixed it within an hour and everything worked except the backlight which is a blown bulb now...
My Videos
AQ + AA/Fi FTMFW!!!!!
ahh true well thanks guys ill rewire it, but iv never had any crazy problems liek that just the lights the head unit turns on and everything works normally but thanks ill check it out
-2 gauge wire.
-a2400db
-mtx 6.5(front)
  • Who's Online   0 Members, 0 Anonymous, 1011 Guests (See full list)
