i just ordered two used 18 xlc and one of the coil is making noises when installed, but it does not smell like burn coils..im thinking the stupido carriers threw the box around and the magnet is not aligning in the right spot could this be true? im saying this because i had a 15 jl and one magnet was off and when i played it, it was making coil noises and took it out of the box and found out that the magnets were not aligned. Got a rubber hammer and bangged it back in place and works fine.
were they freshly reconed at all?
if so, the guy might not of shimmed them right, and the coil could be rubbing against the pole piece
well, peeling the cap off will either ruin the cone, or the dome itself
so.... that is something you might not want to do
its possible metal debris got sucked in to the motor assembly, so getting a blow gun, and blowing off the coil assembly
actually, you said this is the XLC right? stamped steel frame, there is no cooling vents in the frame to suck in debris, if debris went in thru the pole piece cooling vent, then your just kinda fuked
actually there is, but there is a metal screen there. would the metal screen be big enough to suck in debris? i tried pounding the the magnet to see if it will go in place but no luck.
all you need is a piece of metal the size of a grain of sand, even smaller to get sucked in there
that VC gap is like a black hole for metal shavings, screws, etc
if its saw dust, a simple blow gun would get rid of it
if i try pressing it down with my hand i can still hear it. i hooked it up and bump a little and was still making the noise, but once i push the cone up a little and hold it, it bumps freely without hearing the coils rubbing
