What Do I Need To Buy
I have a Vauxhall corsa B with the stock alt and battery(35ah) and i want to get a Kicker 06ZX 750.1 and two 12" L7's. What would i need to upgrade, what size of wire and fuse.
This is my first car and build so i don't really know much
kicker 750.1 ........... if you can run 1/0 in case you upgrade to a bigger amp later ......... but if not 1/0 then go no less than 4ga. as for the battery and alt ......... if you decide to upgrade i'd go with a bigger alternator first and then add a battery or two later.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
could i use 50mm welding cable instead of 1/0, would i need to make 2 runs or could i bolt the earth to the body
what battery's should i get
will i need to do the big 3
Thanks
convert that 50mm to gauge wire potna. as for batteries go with Powermaster, kinetik or stinger and yes do the BIG 3. read around on the Electrical section of this forum man. school yaself.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Guest Just_Rob
Which year and engine do you have? We have done a few alternators for the Corsas' and sent them across the pond... Opels are very popular cars to modify!!
  • Who's Online   0 Members, 0 Anonymous, 929 Guests (See full list)
