I have 2 12.2 Orion Hcca's. One is brand new, never used. I still have the original box for that sub. Also comes with a 2 week old (still hasnt been broken in) Hifonics 2608d amp. I have the original box, bass knob, and manual for that. All the equipment works great! There are NO scratches or marks on the amp (just wire hair in pics). One of the subs has some scuff from when the audio place built my box for them. All of this for $1000!!!
I have a box that is built to specs that fits a 99 Gmc sierra extra cab for an extra $125. You could Cut the bottom off if you wanted the box as well. It's like a little stand, hard to explain. I can send you more pics of that if you want to see closer.
About the subs:
Power(RMS/Peak) 2000/4000
Fs (Hz) 36
Qts .53
Vas (cu ft) .812
SENSITIVITY 84db
LINEAR EXCURSION 30mm
DIMENSIONS (in) 11.9 x 10.7
4” copper Wound Voice Coil on an Aluminum Former, High temperature PAARC (Polyester Amide, Amide Resin Coated)
Continuous power handling will be 1500W (under rated)
Peak power handling: 10” 3000W 12 & 15” 4000W
Burp power in excess of 4000W on 10” and 5000W on 12 & 15”
X-Max estimated at 30mm (total travel 4” peak to peak)
Field Replaceable Cone / Voice coil / Spider Assembly
Dual Flat Conex Spiders with Loop/Stitched Tinsel Leads
Tall, wide, balanced, Foam (high density expanded polyester foam) surround for linear controlled long excursion using a Tri-Radius symmetrical edge design optimized on non-linear FEA
Enhanced voice coil cooling system (forced convection – aluminum heat sinking – shorting rings to reduce inductive heating)
About the amp:
BXi 2608D 1 x 850 W @ 4 Ω / 1 x 1700 W @ 2 Ω / 1 x 2600 W @ 1 Ω
General pic of the sub
T10004
10" AQ HDC3
yep in a prius.. I know, I know why a prius..
How much just for the amp?
I just paid $450 for it 2 weeks ago, but I will sell for $380 since it has to be shipped.. The subs are $550
T10004
10" AQ HDC3
Am I asking to much?
just a bit i think, but i dont know much about the orions i just see alot of other things cheaper on here
Edited by tudski
1996 deville on 18" full face rims
-2 gauge wire.
-a2400db
-RE SE-X in a 4ftc box tuned to 32hz
-tview touch double din
-rockford punch 6x9s(rear)
-mtx 6.5(front)
front and rear stage will soon be changed build log will start as soon as it aint cold!
How's $875 shipped? for everything except the box ^_^ One of the subs is BRAND new back in the original box, and the amp is back in the original box as well. They're selling on ebay for $350 brand new, I'm selling both the subs for $250 (each) and the amp for $300.
T10004
10" AQ HDC3
Willing to peice out
T10004
10" AQ HDC3
This topic is now closed to further replies.
