Feedback On Enclosure
95_1500
I wanted some of the more experienced designers feedback on this. My dimensions are VERY strict so this is about the best i can come up with.
Specs:
6.24 ft^3 after port displacement
~32 hz
98 in ^2 port area (7 wide x 14 tall)
34" long port
This is for two 15s inverted
My one real question is that when you have a 7"wide port to the back then split it off to both sides in half the width (3.5 in my case). You have to double the length right because you have half the area. Like for instance it is 34" long and the 7" section is 12.5" and each 3.5" one is 21.5". So if im correct it is the 3.5 wide sections x 2 gives you the area of the 7" at a length of 21.5 and then that + 12.5 = the 34" i need right?
Sorry so wordy
should be ok...might not be ideal
make the port width smaller and use the entire height
or
make a port on top and bottom... to keep same sqin/cuft
the entire enclosure might not be utlilized by the sub since theres so much below the sub and port
it might "see" or "think" there's less volume, which would then throw off tuning
depends on whether the back of the box is flat or contoured in some way to the vehicle with fg
Or one other option is to just invert the new subs. The reason im thinking about rebuilding is because the new subs have a MUCH larger magnet and mounting depth so they would hit the bottom the box at the angle they are right now. Do you guys think the magnets being up high would interfere a lot since they would be in front of the port if i use the current box?
well can u lower the subs.... make the wall flat, not angled... and do the port like in the pic above... then ud be much better off imo
Guest Leilani Jade
Looks like your drawing would have standing waves
  • Who's Online   0 Members, 0 Anonymous, 4798 Guests (See full list)
