yea im going to be using 1/0 anyway. the fuse i have running from the batt to the batcap is 250amp, do i need the same amp rating from the batcap to the amplifier also?
i would. wont hurt anything
that was a major problem at the audio shop about running an extra ground from the front to batcap. most shops said to just stick with the OK diagram. but as it shows the batcap is grounded to the amp and that's impossible because a amp only has one ground. now you could use the same grounding point as the amp. but we all know capacitors and amps should be grounded separately. regardless i have still heard good things about the batcap.
ive heard differently. you can do that, or ground your amp to the cap, and a seperate ground for the amp too.
yea i think im jus going to follow the diagram they give on their site. lol, i mean i should hope that these guys know what they are talking about since they invented it. i pray they are as good as the help ive gottten in the past from meades forums.
