Help On Enclosure
c406
Hello there, im new here, im in need on a bit of help on the measurements of the enclosure, im currently using 2 of these subs and powered by boss, 3000watts monoblock class D 1 channel amplifier. This will be inside a 97 RD tiburon, and im interested on SPL, therefore what type of enclosure and what do u need to help me to calculate the measurements for the enclosure? on the sub link i gave, theres a manual if you guys need few info of the subs. thank you. and im sorry if this is rude. any help will be really appreciated.
so a 500 rms amp and 2 subs that are
Impedance 4 Ohm + 4 Ohm
Peak Input Power 750+750 Watts
Rated Input Power 190 + 190 Watts
Max Input Power 1500 Watts
is that 380 rms or what
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 4798 Guests (See full list)
