a_steezy Posted December 9, 2008 Author Report Share Posted December 9, 2008 i really wanna know if there is any difference? Quote '98 Dodge Durango 5.9L 5% front windows, 2.5% on all backs Alpine CDA-9883 Kicker ZX350.4 Kicker KS650's in all doors Kicker 1/0 hyperflex Link to comment Share on other sites More sharing options...
ryde2idie Posted December 9, 2008 Report Share Posted December 9, 2008 A 1 ohm load is gonna be harder on your electrical because its allowing more current to flow to your subs rather then resisting it. and if more current is flowing to the subs your amps have to pull it from your electrical which makes it hard on your alternator to keep producin it. so a 1 ohm load is harder on your electrical. Quote Quote Link to comment Share on other sites More sharing options...
Boon Posted December 9, 2008 Report Share Posted December 9, 2008 Gah. Some people just don't know what they're talking about. 2500w @ 1 ohm will draw exactly the same current from your electrical as 2500w @ 2 ohms IF the amps had 100% efficiency. Power in x efficiency = power out Most amps are quite a bit more efficient at 2 ohms than 1 ohm but a 2500w @ 2 ohms amp is going to draw almost as much current as a 2500w @ 1 ohm amp. Difference in efficiency might be 5-10% depending on the amps so you're maybe talking 300A for the 2500 @ 2 amp and 330A for the 2500w @ 1 amp. Quote 10.x volts fo' life! Link to comment Share on other sites More sharing options...
ryde2idie Posted December 10, 2008 Report Share Posted December 10, 2008 my bad thought we were using the same amp in a 1 ohm or 2 ohm situation. Quote Quote Link to comment Share on other sites More sharing options...
