Bass4Lyfe Posted December 15, 2008 Report Posted December 15, 2008 The car is drivable witht he fuse blown, sorry that's just exactly what happened to me so it might be worth checking but sorry didn't meant o put words in your mouth bro! Quote ~Matthew 1998 Toyota Camry XLE V6 3L (1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm with Shock and Proximity (1) 20% Tint All Around (Gately Audio) (1) 250 Amperage HO Alternator (1) Big 3 Done In 1/0 (2) Kinetik HC2400 Power Cell (1) Alpine IVA-D106 Receiver (1) Peripheral Video Bypass Device (4) Alpine SPS-17C2 Speakers (1) Alpine KCE-422i iPod Control Interface (4) Sheets Dynamat Extreme; for speakers (1) 10 Square Feet Hushmat (Trunk & Rear Deck) (4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils (1) Wall Built By David, Tuned to 32 Hz (1) Rockford Fosgate T40001bd Amplifier (1) Stinger 1/0 Wiring (2 runs of + 2 runs of -) (1) Stinger Volt Meter
ChevyBoy Posted December 15, 2008 Author Report Posted December 15, 2008 i mean the factory alt is putting out power. which means it cant be the fuse other wise this one wouldnt work. i still believe it has to deal with the harness......im hoping. im callin him in the morning Quote
Bass4Lyfe Posted December 15, 2008 Report Posted December 15, 2008 oh, didn't know the factory alt was working. yeah he is usually very helpful so GL on the call! Quote ~Matthew 1998 Toyota Camry XLE V6 3L (1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm with Shock and Proximity (1) 20% Tint All Around (Gately Audio) (1) 250 Amperage HO Alternator (1) Big 3 Done In 1/0 (2) Kinetik HC2400 Power Cell (1) Alpine IVA-D106 Receiver (1) Peripheral Video Bypass Device (4) Alpine SPS-17C2 Speakers (1) Alpine KCE-422i iPod Control Interface (4) Sheets Dynamat Extreme; for speakers (1) 10 Square Feet Hushmat (Trunk & Rear Deck) (4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils (1) Wall Built By David, Tuned to 32 Hz (1) Rockford Fosgate T40001bd Amplifier (1) Stinger 1/0 Wiring (2 runs of + 2 runs of -) (1) Stinger Volt Meter
missinglink Posted December 15, 2008 Report Posted December 15, 2008 i mean the factory alt is putting out power. which means it cant be the fuse other wise this one wouldnt work. i still believe it has to deal with the harness......im hoping. im callin him in the morning What kind of "harness" did you need? Should be a plug and play swap if its for a GM you either have AD or CS which going from a factory AD to a CS is not the best any way its kind of a down grade.(in our own opinion) PM just_rob he will tell you the same thing. Have them get you the correct alt for your factory plug and you should be fine. 3rd times the charm bro please PM him to cause like I said even we sometime only check our sections and just miss questions in other sections about our products. Give them the chance i'm sure they will get you fixed up. MLA Quote missinglinkaudio The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander...
Stephen Posted December 15, 2008 Report Posted December 15, 2008 What kind of "harness" did you need? Should be a plug and play swap if its for a GM you either have AD or CS which going from a factory AD to a CS is not the best any way its kind of a down grade.(in our own opinion) PM just_rob he will tell you the same thing. Have them get you the correct alt for your factory plug and you should be fine. 3rd times the charm bro please PM him to cause like I said even we sometime only check our sections and just miss questions in other sections about our products. Give them the chance i'm sure they will get you fixed up.MLA his is for a 06 or 07 civic, dont know if you caught that Quote you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
missinglink Posted December 15, 2008 Report Posted December 15, 2008 his is for a 06 or 07 civic, dont know if you caught that Didn't see that bit of info any where was going by his forum name. LOL no worries it still should apply its just wrong make / brand car. The harness part still fits my reply. Thanks, MLA Quote missinglinkaudio The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander...
missinglink Posted December 15, 2008 Report Posted December 15, 2008 08 Shit we were off lol. All good MLA Quote missinglinkaudio The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander...
ChevyBoy Posted December 15, 2008 Author Report Posted December 15, 2008 so since honda is gay and has that 4 pin harness, that was the deal. the one wire that turns the alt on, was only seeing 4.8v. there was another one seeing 12.31 with the key in the "on" position. i resoldered that wire and it should work. ill keep you guys updated. i should be reinstalling it tomorrow after work (4ish). Quote
missinglink Posted December 15, 2008 Report Posted December 15, 2008 so since honda is gay and has that 4 pin harness, that was the deal. the one wire that turns the alt on, was only seeing 4.8v. there was another one seeing 12.31 with the key in the "on" position. i resoldered that wire and it should work. ill keep you guys updated. i should be reinstalling it tomorrow after work (4ish). Sweet , hope it gets you rollin and problem solved. MLA Quote missinglinkaudio The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander...
