i jus would like to get a final answer on which side of the car wire should be run to eliminate road noise?  i thought RCA's and speaker wire can go on the same side, and power wire and REM can go on the other side.
yea run your power down the side of the car th battery is on, and then since your running your rcas run your remote and speakers there aswell....
wait a sec, so power on one side and everything else on the other side??
yea thats what i do only because i do one side at a time, and if you have everything apart to run your rcas from your deck, just run your remote aswell, .... IMO ive never had a problem with doin it that way...
Guest MegaloManiac
road noise?
or are you talkin about alt whine??
Anyways if you dont have decent rca cables(shielded) then do not run them next to the power wire.
power on one side, remote wire and rcas on the other.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Guest MegaloManiac
i have mine all on one side. I've had no problems. As long as you have well shielded wires you can do it.
now that's a chance you take but if you don't get any noise out of it then you're good to go.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   0 Members, 0 Anonymous, 740 Guests (See full list)
