ChiefDankBud Posted December 14, 2008 Report Posted December 14, 2008 I was wondering if i need a new battery, because i recently noticed that the headlights on my car seem to dim when i open or close the windows. Do i need a new battery or alternator? 2003 Pontiac Vibe Dark Red 18" Motegi MR-7's 2 Alpine Type-R 6.5" Coaxial Speakers on the front doors Alpine CDA Head Unit w/IPod Cable Alpine V-Power mono mr650 12" Alpine Type-R(2 Ohm) Subwoofer Dynamat in the trunk with the liscense plate and, 2 Stock tweaters in the front, with the stock speakers in the back seats
Neo_frog Posted December 14, 2008 Report Posted December 14, 2008 I was wondering if i need a new battery, because i recently noticed that the headlights on my car seem to dim when i open or close the windows. Do i need a new battery or alternator? After your car is off, and engine cooled down, check the voltage of your battery. If it's low, that might mean your alternator is not sufficient. Have it load tested at Autozone or other facility to check it. If the alternator checks out and you don't have a super high power system, then a high output battery (or extra battery) should fix the problem. I didn't read close enough... As far as the windows go, is this a new problem or has it always been one? Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
