Sundown 3000
What kinda power do you guys think ill need to run this bad boy. i was thinking 200 amp alt and either 2 kinetik 2400's or powermaster 3100's then the biggest battery i can get to fit up front. then probably 2 runs + and 2 runs - . you guys think that will be enough ?
1999 grand prix gt
kenwood x994 head unit
1/0 big 3 all shok industry single run to the back
New mid/highs coming not sure what
Soundqubed q2200d at .5 (have)
2 soundqubed hdc3 12s (have)
New box to be built.. sealed firing forward (yet to be designed)
200 amp alt not sure exact size or manufactor xs power batts
alright cool.
1999 grand prix gt
Yea, you should be golden. I'm going to run a SAZ-3000d and 3 SAX-100.4D's off of a 250a alt, 1 HC1800 under the hood and 2 HC2400s in the trunk.
97 Maxima SE
Bunch of shit going in, check out the build
Guest reestblazer
3 100.4s and a sundown 3k off a 250 amp alt and 2 kinetik 2400s? depending the impedence your going to run that sundown at, your deff. going to have voltage drop.
Don't forget the HC1800 under the hood. I'm not using an isolator, so they will all be in the loop. 100.4's at 4ohm 4 channel, 3000d at 1 ohm. Even Jacob said that would be ok for a Daily Driver. For Burps, if I even do that everynow and then should be ok. I'm also having a MLA module preinstalled on the alt.
I guess the beauty of it is, I can always add a couple more 2400's if I still get drop.
97 Maxima SE
  • Who's Online   0 Members, 0 Anonymous, 1264 Guests (See full list)
