Zfrerichs's 01 Dakota floor project started
build looks great! what kind of drill bit did you use to drill all the holes on the baffle?
i just drill pilot holes in it with a regular spiral bit and then the screw will sink it self in a little bit
Roseville, CA
i got the edges all flush i cut the most of it off witht a skil saw then i got the belt sander and sanded the day away
Posted Image
Posted Image
Posted Image
Posted Image
then i got some of the dyna hair out again and filled all the edges and sanded um down they are ready for bondo later
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
came out pretty straight
Posted Image
Roseville, CA
i had to go and buy a new camera at best buy, my other one fell of the bed and the lens wont go back in i grabbed this one from there
Kodak Camera
then i test fitted this shit and it fits so perfect. i was hella happy :D
it fits so tight it doesnt move when you grab it and try to shake it out but itll still get bolted down with 8 bolts or so
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Roseville, CA
fuck it better be snug, the thing looks like it weighs 30094580938 pounds
R.I.P!
(Nov-29-2009)
92 explorer
current build
wow :shok:
My daughter's (kimberly) hairtrick via the duckman
i had to clean out the garage and go to the dump today it was getting out of hand with all the projects so i didnt get alot done but i got some sanding done
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
i gotta go to my birthday dinner then im puttin some more resin on the box but bondo and what not tomorrow on the a pillar the other one is being a bitch! the glue wont stick so im going to screw it in
we have the same birthday! :drinks:
so i donno if this has been asked or not but where are you mounting the amps
R.I.P!
(Nov-29-2009)
92 explorer
current build
i dont want a tonneau cover so they will have to go in the cab on top of the box. i got 56 inches long and like 15 incehs wide with 14 high to mess around with
Roseville, CA
