How Dose A Port
fischy fisch
can any one help explain a port to me and how tuning affects it and all the other good stuff
plz pm me
lol. but i haven't and i don't plan on it. plus i'd probably miss and hit her belly button or her ear or something. lol.
http://en.wikipedia.org/wiki/Bass_reflex
"type of loudspeaker enclosure that uses the sound from the rear side of the diaphragm to increase the efficiency of the system at low frequencies as compared to a typical closed box"
the more amount of port, the higher the tuning will be, the less amount of port the lower the tuning will be.
http://subwoofertools.com/calculator_displ...mp;sheet_size=0
in that link i used a 12" Fi BL with a box tuned to 30hz, notice the amount of space inside the 2 bends in the port and the response graph at the top. notice the little flat bump at around 30hz also.
here is the same box tuned to 40hz, http://subwoofertools.com/calculator_displ...mp;sheet_size=0 . notice how this time the bump is around 40hz and more space in the port.
tuning a box to different frequencies, like 30hz, 35hz etc, will change how it sounds and what notes it will play.
tuning a box to a low number like 30-32hz will have great low output but will sacrifice upper bass, around 60-70hz. tuning a box to a higher number like 40hz will have terrible low output but insane high frequency output.
tuning a box lower will make it a little quieter, but have greater low note output and lower high note output. a higher tuned box will be louder in general, especially at the higher frequency's but no so much at the lower notes.
if you play a note that is under the box tuning, it will "unload" or pretty much bottom out extremely easily if your not careful, thats why 99% of subwoofer amps come with a Subsonic filter which filters out frequencies below a set point (you set the point of the freq. cutoff)
sweet...can you throw one up for an FI BL15? :D
1990 Jeep Cherokee 4X4
Pioneer DEH-P2900MP, Big 3 done in 1/0, 1 run 1/0 ran to amp
DAT HF1000.1 #007 powering a DC lvl4 15
DAT HR 4085 prototype powering 2 Selenium 6s and 2 no name tweeters running active
1st place in AS3 @ Surf City Sound Off, 140.8 @ 45hz @ the headrest.
rebuild coming soon to get a better score :)
"I regard the brain as a computer which will stop working when its components fail. There is no heaven of afterlife for broken down computers; that is a fairy story for people who are afraid of the dark."
  • Who's Online   0 Members, 0 Anonymous, 589 Guests (See full list)
