Bass4Lyfe Posted January 1, 2009 Report Share Posted January 1, 2009 (edited) Okay, now that everything is in, time for some testing on my part. History: The belt on my alternator has been slipping (the load is 4x the stock load on the belt) and I need to solve that problem. Today's testing will include 1) Belt timing test, by hooking to spark plugs and usingthat strobe light timing thing to find out where it's slipping (my dad's equipment, I forgot the name) 2) Check all engine grounds, etc. for tight connections and etc. 3) Check voltage drop throughout all wires and make sure I don't need to upgrade to 2/0 from batt's to the amp (its about a foot only...) 4) Use a clamp-on ampeter (sp) to test alternator output. if less than 250 (significantly) i know the belt is slipping 5) Use my new (got it for christmas) DMM's high/low feature to check for lowest voltage at batts, and at amp while full tilting 6)Check RCA voltage and make sure both channels are equal at exactly 6 volts 7) GET PICS AND VIDS FOR YOU GUYS Edited January 2, 2009 by Bass4Lyfe Quote ~Matthew 1998 Toyota Camry XLE V6 3L (1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm with Shock and Proximity (1) 20% Tint All Around (Gately Audio) (1) 250 Amperage HO Alternator (1) Big 3 Done In 1/0 (2) Kinetik HC2400 Power Cell (1) Alpine IVA-D106 Receiver (1) Peripheral Video Bypass Device (4) Alpine SPS-17C2 Speakers (1) Alpine KCE-422i iPod Control Interface (4) Sheets Dynamat Extreme; for speakers (1) 10 Square Feet Hushmat (Trunk & Rear Deck) (4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils (1) Wall Built By David, Tuned to 32 Hz (1) Rockford Fosgate T40001bd Amplifier (1) Stinger 1/0 Wiring (2 runs of + 2 runs of -) (1) Stinger Volt Meter Link to comment Share on other sites More sharing options...
Stephen Posted January 1, 2009 Report Share Posted January 1, 2009 if you did the big3 and left the stock + batt to alt wire, dont forget to put that in the clamp too. Quote you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER Link to comment Share on other sites More sharing options...
Bass4Lyfe Posted January 1, 2009 Author Report Share Posted January 1, 2009 good point, thanks man Quote ~Matthew 1998 Toyota Camry XLE V6 3L (1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm with Shock and Proximity (1) 20% Tint All Around (Gately Audio) (1) 250 Amperage HO Alternator (1) Big 3 Done In 1/0 (2) Kinetik HC2400 Power Cell (1) Alpine IVA-D106 Receiver (1) Peripheral Video Bypass Device (4) Alpine SPS-17C2 Speakers (1) Alpine KCE-422i iPod Control Interface (4) Sheets Dynamat Extreme; for speakers (1) 10 Square Feet Hushmat (Trunk & Rear Deck) (4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils (1) Wall Built By David, Tuned to 32 Hz (1) Rockford Fosgate T40001bd Amplifier (1) Stinger 1/0 Wiring (2 runs of + 2 runs of -) (1) Stinger Volt Meter Link to comment Share on other sites More sharing options...
Bass4Lyfe Posted January 2, 2009 Author Report Share Posted January 2, 2009 (edited) Results DMM set on "min", amplifier ON car ON MIN VOLTS = 12.13 VDC Alt output around 200 amps, belt slipping a lot so I am missing out on that extra 50 amps any ideas?? the belt is TIGHT voltage drop @ 300amps from rear battery to amplifier is .08v RCA RMS voltage (AC) into amp, from line driver, 5-7. 10.3 v on a sin wave 35 hz (is this bad?) EDIT vids TAKEN have to go to work to upload, so 2morow Edited January 2, 2009 by Bass4Lyfe Quote ~Matthew 1998 Toyota Camry XLE V6 3L (1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm with Shock and Proximity (1) 20% Tint All Around (Gately Audio) (1) 250 Amperage HO Alternator (1) Big 3 Done In 1/0 (2) Kinetik HC2400 Power Cell (1) Alpine IVA-D106 Receiver (1) Peripheral Video Bypass Device (4) Alpine SPS-17C2 Speakers (1) Alpine KCE-422i iPod Control Interface (4) Sheets Dynamat Extreme; for speakers (1) 10 Square Feet Hushmat (Trunk & Rear Deck) (4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils (1) Wall Built By David, Tuned to 32 Hz (1) Rockford Fosgate T40001bd Amplifier (1) Stinger 1/0 Wiring (2 runs of + 2 runs of -) (1) Stinger Volt Meter Link to comment Share on other sites More sharing options...
kentb Posted January 2, 2009 Report Share Posted January 2, 2009 (edited) i don't think its the belt but if you want replace it get the goodyear gatorback belt from autozone. i replaced my stock belt with it and its been runnin good ever since. no squeeling at startup Edited January 2, 2009 by kentb Quote New System 2 10" Fi SSD, Sundown 1500d Build I build and design enclosures(cheap price), PM ME Kicker L7 Navigator(plexiglass, fiberglass, aeroport) Build BTL 18" Escalade(plexiglass, battery tray) Build http://www.kentbaudio.com Old System Link to comment Share on other sites More sharing options...
Bass4Lyfe Posted January 2, 2009 Author Report Share Posted January 2, 2009 if its not the belt what should i do, to fix the problem? and i will replace w/ gator back on monday Quote ~Matthew 1998 Toyota Camry XLE V6 3L (1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm with Shock and Proximity (1) 20% Tint All Around (Gately Audio) (1) 250 Amperage HO Alternator (1) Big 3 Done In 1/0 (2) Kinetik HC2400 Power Cell (1) Alpine IVA-D106 Receiver (1) Peripheral Video Bypass Device (4) Alpine SPS-17C2 Speakers (1) Alpine KCE-422i iPod Control Interface (4) Sheets Dynamat Extreme; for speakers (1) 10 Square Feet Hushmat (Trunk & Rear Deck) (4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils (1) Wall Built By David, Tuned to 32 Hz (1) Rockford Fosgate T40001bd Amplifier (1) Stinger 1/0 Wiring (2 runs of + 2 runs of -) (1) Stinger Volt Meter Link to comment Share on other sites More sharing options...
Noobtastic14 Posted January 2, 2009 Report Share Posted January 2, 2009 Gatorback ftw- then see if it keeps slipping -Drew Quote I am a United States Military Arts and Crafts Professional. Sand it off, Paint it on. uhoh_45 said: dont be a pussy P give the jeep to drew Link to comment Share on other sites More sharing options...
Bass4Lyfe Posted January 2, 2009 Author Report Share Posted January 2, 2009 kk, thanks a lot drew! ps i wanna visit u soon!! Quote ~Matthew 1998 Toyota Camry XLE V6 3L (1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm with Shock and Proximity (1) 20% Tint All Around (Gately Audio) (1) 250 Amperage HO Alternator (1) Big 3 Done In 1/0 (2) Kinetik HC2400 Power Cell (1) Alpine IVA-D106 Receiver (1) Peripheral Video Bypass Device (4) Alpine SPS-17C2 Speakers (1) Alpine KCE-422i iPod Control Interface (4) Sheets Dynamat Extreme; for speakers (1) 10 Square Feet Hushmat (Trunk & Rear Deck) (4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils (1) Wall Built By David, Tuned to 32 Hz (1) Rockford Fosgate T40001bd Amplifier (1) Stinger 1/0 Wiring (2 runs of + 2 runs of -) (1) Stinger Volt Meter Link to comment Share on other sites More sharing options...
Noobtastic14 Posted January 2, 2009 Report Share Posted January 2, 2009 (edited) u hitt'n on me now? -Drew **gotta buy me dinner first Edited January 2, 2009 by Noobtastic14 Quote I am a United States Military Arts and Crafts Professional. Sand it off, Paint it on. uhoh_45 said: dont be a pussy P give the jeep to drew Link to comment Share on other sites More sharing options...
Bass4Lyfe Posted January 2, 2009 Author Report Share Posted January 2, 2009 hahahahaha no Quote ~Matthew 1998 Toyota Camry XLE V6 3L (1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm with Shock and Proximity (1) 20% Tint All Around (Gately Audio) (1) 250 Amperage HO Alternator (1) Big 3 Done In 1/0 (2) Kinetik HC2400 Power Cell (1) Alpine IVA-D106 Receiver (1) Peripheral Video Bypass Device (4) Alpine SPS-17C2 Speakers (1) Alpine KCE-422i iPod Control Interface (4) Sheets Dynamat Extreme; for speakers (1) 10 Square Feet Hushmat (Trunk & Rear Deck) (4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils (1) Wall Built By David, Tuned to 32 Hz (1) Rockford Fosgate T40001bd Amplifier (1) Stinger 1/0 Wiring (2 runs of + 2 runs of -) (1) Stinger Volt Meter Link to comment Share on other sites More sharing options...
