donny Posted January 7, 2009 Report Posted January 7, 2009 i have 2 runs of 2awg from front to back and 2 smaller pieces for grounding do i need to put a fuse on each positive wire or can i tack a small piece of 0awg and put a fuse in that and bolt the 3 terminals together will i need to i need to use 0awg from the battery to the body
C 45. Posted January 7, 2009 Report Posted January 7, 2009 not exactly sure what you mean but its best to use the same wire all the way around ground and power if your running two runs of power its best to fuse both although i dont even fuse my wires more current but i do not recommend doing that at all must be nice huh
