djronbxs Posted January 15, 2009 Report Posted January 15, 2009 Hi, I have a citroen saxo 1.1 (2001), I have all standard alternator but I upgraded a little bit the battery. Im running a pioneer class-D amplifier 700w rms and another amplifier 200w rms. When I turn up the volume during a bass note I have a little bit of dimming in lights. do you think that with the big 3 upgrade my problem will be solved ? thanks ron
dmanson Posted January 15, 2009 Report Posted January 15, 2009 Hi,I have a citroen saxo 1.1 (2001), I have all standard alternator but I upgraded a little bit the battery. Im running a pioneer class-D amplifier 700w rms and another amplifier 200w rms. When I turn up the volume during a bass note I have a little bit of dimming in lights. do you think that with the big 3 upgrade my problem will be solved ? thanks ron the BIG 3 can possible help. do you just the stock battery? if so then upgrade it to an optima, kinetik or powermaster. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
djronbxs Posted January 15, 2009 Author Report Posted January 15, 2009 I have a delphi which is quite large for the car ie a battery that has more amps than the standard one
Beckett Posted January 15, 2009 Report Posted January 15, 2009 I have a delphi which is quite large for the car ie a battery that has more amps than the standard one do the big 3 in 1/0 wire, get a deep cycle battery, maybe another one in the back, that'l help, but the best way to is jus get a bigger alternator and more battery storage JS Fraser *Alpine Typr-R 12" *JBL GTO 1200.1 Sub Amp *Alpine PDX-4.100 *Rockford Fosgate Power 6.5's *Rockford Fosgate Fanatics 6.5's Both in front doors *0/1 Guage wiring from front Junction Boxes to 120AH Battery In Boot (battery removed because too small for alternator) *140 Amp HO Alternator *Alpine Head Unit -------------------------------------------------------------------------x------------------------------------------------------------------------------
