Wiring Subs For Strapping Amps
I'd just use one terminal cup I think it'd be easier. Inside the box wire each sub in series to 4 ohm then wire the two subs together in parallel to a 2 ohm where they connect to a single terminal cup. then from the cup to the amps.
cool thanks strapping amp @2ohm am i going to have less strane on my eletracle as opossed to running one big amp @0.5ohm
then wire the pos to pos of one amp and the neg to the other amps pos
then run amp neg to amp neg and dont forget to put one in master/br out and the other in slave/br in and your done
see link here for more
http://www.soundsolutionsaudio.com/forum/i...?showtopic=7406
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
Depends like say with 2 sundown 1500's strapped to 2 ohm is basically equivalent or if i remember correctly more power hungry than a single 3000 ran at 1 ohm. But if the smaller amps are half the size of the one big amp you speak of then yes that will be MUCH easier on the electrical than a big one at .5ohm
This is not always true. Depends on the amplifier and whether the master/slave arrangement flips the phase or not.
It's specific to the amp - do it wrong and the amps will fight each other.
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 1179 Guests (See full list)
