bass 4 love Posted January 23, 2009 Report Posted January 23, 2009 with this setup do i a battery in the back cause when the bass hits the volts goes to about 10-11 sometime 9? also whats the required voltage the T20001bd needs
Punkeyboozter Posted January 23, 2009 Report Posted January 23, 2009 fist of you may start by removing that capacitor. Keep your wires short. what battery are you using? ..and what is the output of your alt? Loudness is no substitute for musicianship, and partial deafness is no badge of honor. I was once able to hear this advice. Build Log>>> http://www.stevemeadedesigns.com/board/ind...pid=672024& New Build Believe in the order
finkster Posted January 23, 2009 Report Posted January 23, 2009 First upgrade the front (Big 3, HO alt)...and yes you will need at least 2 batteries in the back. That other amp only adds more current draw to your system....anytime your voltage drops like that you def need to upgrade your charging system and also that cap is useless DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
Bills Posted January 23, 2009 Report Posted January 23, 2009 ya man, the cap there wont help at all. may be hurting. haha. but ya. upgrade your electricl up front and then add another batt or two in back. Bills KwB Team DC Audio Midwest captain
bass 4 love Posted January 23, 2009 Author Report Posted January 23, 2009 fist of you may start by removing that capacitor. Keep your wires short. what battery are you using? ..and what is the output of your alt? 175
bass 4 love Posted January 23, 2009 Author Report Posted January 23, 2009 Here are the subs its 6 15's
