First I have a:
97 GMC Sierra Ext Cab 2wd
5.7 with a few mods
Rebuilt Transmission as of 2 yrs ago
Fully Bagged and lays frame
Well my transmission started slipping . . . so yea I have to get it rebuilt apparently. But the guy at the shop told me I probably have to get my drive shaft shortened because it's in a bind against the transmission.
Well considering I have many more performance upgrades planned and possibly a 454 swap in the plan I would like to know what a good performance transmission would be (like some links!). I already have a shop lined out to shorten my drive shaft. So instead of rebuilding a crappy stock tranny I'd be more comfortable shelling out the few extra bucks for a better one.
i've heard good things about bowler transmissions, you need to call for the price.
this will be a direct swap.
http://bowlertransmissions.com/default.aspx?mpid=36
a couple others
i've read good things about these guys as well
http://www.finishlinetrans.com/transmissio...ormance4L60.htm
http://www.aceracingtrans.com/sitebuilder/...ctive-50281.png
center console: lvl 4 12 1.75 cu ft tuned 37htz
alpine cda-9886
dc audio 120.4
infinity kappa 6.5" components
The bottom brace that holds the driveshaft in the middle Tub, did they put spacers under it to lift the shaft, if not it will be a reason why the tranny failed after 2 years. On mine when we dropped it 7 in the rear we had to cut the bottom of the truck brace cause it sat on the drive shaft.
Do you get any type of shimmy's when you excelerate from a dead stop?
Edited by Andrew2944r
Team Ampere Audio
