2 Quad 1 Coil Subs To .5 Ohm
i have 2 quad 1 ohm coil woofers and need to wire the pair to .5 ohm total load
so each sub should go
+ to +, - to - on each side to wire it to basically 2 2 ohm coils correct?
then take one of the posotives to the other side to a negative criss crossed right?? that should give me 1 ohm total for 1 woofer?
then im am left with 1 + and 1 - on each sub and go negative to positive on the other sub and vice versa for .5 ohm total?
1 15" LMS Ultra<-Sold
2 12" Audiopulse Axis Quad Coils
2 18" RD Audio Alpha V2's<--For Sale or Trade
American Bass VFL 700.1 (alot of power at any ohm)
American Bass VFL 200.1 (3.8k rms @ .5 ohm)
2.1 cubes each at 32 Hz
125 sq ft RAAMaudio BXT, 5 Yards Ensolite
50ft 1/0 Knu Flex wire
4 Infinity 6.5"
Temp 170x2@2 ohm Sony amp
200 Amp EA Alt
3 Exide Orbital's
Youtube Vids....http://www.youtube.com/profile?user=gavinriley&view=videos
Guest digitalboy
To get what you after, I think you would need to run the + from on coil to the - of another. then the - from the firs to the + of the second. giving you 2 ohm. Repeat on other side, and then you are at basically a D2 woofer. The when you did the same to the other sub, you take all the +'s and hook them up and all the -'s and hook them up to each other.... and your at .5
That seems right. O.o
confusing ...... but close
What he said :D
Series a pair of coils on each woofer then parallel the lot :)
10.x volts fo' life!
Guest digitalboy
I was hoping I was right lol
I could have just said series the two coils then parallel. But I figured i try to explain it. :D
thanks guys they are bumpin..... wait for the vids in the next two days, i thought my LMS Ultra had some flex power.... i give my car 1 year and the wheels fall off
4 Infinity 6.5"
200 Amp EA Alt
3 Exide Orbital's
  • Who's Online   0 Members, 0 Anonymous, 979 Guests (See full list)
