if you've got 5 g31s then you should be good just wire your shit up like the photo and you'll see some results
R.I.P!
(Nov-29-2009)
92 explorer
current build
Whoops, meant to say I have the front ones. G34 smaller ones.
2001 Chevy Impala
Eclipse CD7200 mkii
Cactus Sounds 5kw
Sundown 100.4
(2) Fi BTL 18s (walled)
ID 6.5s (2 sets)
Iraggi 320 amp Alt
XS Power Batts
KnuKonceptz Wiring
MidwestSPL Scores:
152.0 Advanced 2
136.1 Extreme 3
my buddy did a setup with a memphis 4kw and 2 mtx 9500 1544's ran at 1ohm with 4 stinger sp800's i think with 1/0 front to back, with a stinger 250 or 300 amp alt i cant remember, he had a stinger cross flow fan to keep it cool, and make sure u run an inline fuse at the amp cause it doesnt have one built in i dont think or its like the other smaller mclass amps with it built in under it? but ive heard yellow tops being perfect for car audio, and then them be shit, thats why i went with a stinger secondary battery and have no problems so far, ied either do powermaster, stinger, kenetik, or what knot
Posted (edited)
I'll be redoing my wiring and have to run the batts I got now for the time being. What would a good Kinetik or Powermaster setup be or what I have? Eventually 5kw. Would a D3100 in back and D3400 up front be enough?
Also, both my runs of 0 were fused with 250amp fuses. If I pull one off the batt and put it on my alt I should keep it fused as it is?
Edited by dr hypothesis
2001 Chevy Impala
Eclipse CD7200 mkii
Cactus Sounds 5kw
Sundown 100.4
ID 6.5s (2 sets)
Iraggi 320 amp Alt
XS Power Batts
KnuKonceptz Wiring
MidwestSPL Scores:
152.0 Advanced 2
136.1 Extreme 3
