Need Box Design For 2 12" Dc Lvl 3
t-roy
HERE WHAT MY EMAIL SAID FROM DC For the 2 LV312s I would do 3.0 cubes and 45 si of port 26 inches long. that should work out nice MY TRUNK MAX SPACE IS 36 WIDE 27 DEEP AND 16 TALL I WANT A BOX WITH SUBS FACING BACK AND ALSO THE PORT FIRING BACK? COULD THE BOX BE BIGGER THAT 3 SQ?
STOP YELLING AT ME AND ILL HELP!
why are you not gonna listen to ur email from the company
what amp are you using?
you can go bigger, but depends on some other things... no bigger than 4cuft is needed for those lvl3s
right now hes got u tuned at ~35hz, a little high but depends on what ur looking for
sorry for yelling didn't mean that i gona listen this is for ever day listening i just thinking that port seemed small and so did that box but just wanting some to design me a box
didn't mean to double post i think i got my box all figured out
well for the 3cuft@35 w/45 i got
30w*16h*19d
2.998cuft
3" wide port, 26" long, 43.5sqin
port 1 = 14.5"
port 2 = 6.25"
34.83hz
i included .1cuft for displacement of bracing or double baffle
if you dont do either changes tuning to [email protected]
30w*16h*19d
2.998cuft
port 1 = 14.5"
port 2 = 6.25"
34.83hz
thanks man
thanks man
how do you figure the extra space on top of the 3 cube for the port why are some ports 26 and then some are 16 this is only going to be my second slot box but i love to build and would like to know the whole thing so i can study and know wtf i'm doing some one fill me in one this so i can print it out thank you much troy
Depending on what your dimensions are and the volume of the box you change the port(s) height and/or width/diamater depending on if your ports round or slot shaped, equating to your desired tuning.
Team T3 Audio
Team Sundown Audio
Team O.B.M
Operation Beast Mode
"Believe half of what you see and none of what you hear"
wigglez that was a bit over the top, i dont want to invison dw giving any young lady a "cream pie" let alone "throat babies".
^ what he said...
the longer the length of port the lower the tune frequency when using the same port susrface area
try looking for amatt85's spreadsheet program in this section... pretty easy to use and you can do sealed, round port + slot port
  • Who's Online   1 Member, 0 Anonymous, 589 Guests (See full list)
