LMS15 Posted February 4, 2009 Report Posted February 4, 2009 well i just ordered another 50ft of 1/0 and as of now have 1 run from the front to the back and my old 3kw amp was just grounded out in the back, i want to add another power run and do some ground runs from back to front if it will help my new amp has dual 1/0 power/grounds so does this look about right? so where should i run my amps grounds.... to the front or what? also if i am doing 2 power runs should i double up the rear battery jumper? any answers would help 1 15" LMS Ultra<-Sold 2 12" Audiopulse Axis Quad Coils 2 18" RD Audio Alpha V2's<--For Sale or Trade American Bass VFL 700.1 (alot of power at any ohm) American Bass VFL 200.1 (3.8k rms @ .5 ohm) 2.1 cubes each at 32 Hz 125 sq ft RAAMaudio BXT, 5 Yards Ensolite 50ft 1/0 Knu Flex wire 4 Infinity 6.5" Temp 170x2@2 ohm Sony amp 200 Amp EA Alt 3 Exide Orbital's Youtube Vids....http://www.youtube.com/profile?user=gavinriley&view=videos
bobonit Posted February 4, 2009 Report Posted February 4, 2009 well i just ordered another 50ft of 1/0 and as of now have 1 run from the front to the back and my old 3kw amp was just grounded out in the back, i want to add another power run and do some ground runs from back to front if it will helpmy new amp has dual 1/0 power/grounds so does this look about right? so where should i run my amps grounds.... to the front or what? also if i am doing 2 power runs should i double up the rear battery jumper? any answers would help Ground the amp to the batteries in the trunk. Also, you should put fuses on the positive 1/0 running from front to rear. 97 Maxima SE Bunch of shit going in, check out the build Build Log
