fast85_gt Posted February 7, 2009 Report Posted February 7, 2009 i need to know how to wire 2 batteries in the back of my car they can only fit in each corner of the car i know from front to back is + to+ and -to- then wire the back 2 together + to+ and-to- but what one do i need to power my amps off of does it matter
dmanson Posted February 7, 2009 Report Posted February 7, 2009 i need to know how to wire 2 batteries in the back of my car they can only fit in each corner of the car i know from front to back is + to+ and -to- then wire the back 2 together + to+ and-to- but what one do i need to power my amps off of does it matter not to be a butthole but look down at some of the other topics, i think this how been discussed multiple times this week alone. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
fast85_gt Posted February 7, 2009 Author Report Posted February 7, 2009 not to be a butthole but look down at some of the other topics, i think this how been discussed multiple times this week alone. a simple anwser would be fine seeing you took time to write all that lol
c0smo kram3r Posted February 7, 2009 Report Posted February 7, 2009 Battery under the hood: (+)--[FUSE]------------------------[FUSE]--(+) to one battery. From that one back battery, (+)--[FUSE]----------------------[FUSE]--(+) to other back battery. (If your batteries were closer, you would not have to fuse them but b/c they are on opposite sides, you do.) Now, this is how I plan to wire mine... I think this is right, but someone else could help w/ it probably. I didn't know whether or not to ground the back batts or not.
fast85_gt Posted February 7, 2009 Author Report Posted February 7, 2009 Battery under the hood: (+)--[FUSE]------------------------[FUSE]--(+) to one battery.From that one back battery, (+)--[FUSE]----------------------[FUSE]--(+) to other back battery. (If your batteries were closer, you would not have to fuse them but b/c they are on opposite sides, you do.) Now, this is how I plan to wire mine... I think this is right, but someone else could help w/ it probably. I didn't know whether or not to ground the back batts or not. this looks like something i had in minh thanks for you help
