audioman21 Posted February 7, 2009 Report Posted February 7, 2009 Did some searching but couldn't find anything that helps so..... I have a JVC deck that already has 5volt outputs, so would adding an eq benefit me in any way? I mean I already got the good output voltage so that leaves the extra tuning ability from one. With that being said is buying one worth it?
The Loud One Posted February 9, 2009 Report Posted February 9, 2009 I use an eq in every system. Cars are not an ideal listening environment. An eq will help correct for acoustical characteristics found in automobiles.
b_smiff Posted March 9, 2009 Report Posted March 9, 2009 I had a jvc with 5v outputs and i put an eq on it and it started clippin bc it was too much.. HU: JVC Arsenal AR880 Subs: (4) Incriminator Audio Warden 15s Highs: (12)Eminator 8s (12)Eminator 6.5s (12)Eminence Apt80s Amps: (2) Incriminator Audio 40.1s (subs), (2) MB Quart Discus 4125s, (1) MB Quart 4.80 Electrical: -DB Electrical 275 amp Ohio Gen -BIG III -(5) XS Power d3100s 152.3 In Street Beat 5. State record in Alabama. (USACI) http://www.youtube.com/Itgetslow
Audioguy564 Posted March 18, 2009 Report Posted March 18, 2009 if you get an eq make sure it can handle 5v input or you will clip the input and will sound bad. Juan Rodriguez Chief Technology Officer D'Amore Engineering T15KW Support Engineer System. KVT512 Kenwood Fold Out Monitor Epic-160 Audio control Indash epicenter (1)T1500-1BD with T2000.1 Transformer 1700 watts at 2 ohms (2) T600-2 with T800-2 Transformers 320/ch at 4 ohms (2) QSD216 Q series MB Quart 6.5 inch components (3) P3D212 Rockford P3 12inch Subs (1) Very Loud Altima Coupe!
