uhoh_45 Posted February 10, 2009 Report Posted February 10, 2009 i just got some new dustcaps for my apxx's and am just going to throw them on top of the existing caps now my question is: Is 5 Min Epoxy strong enough to keep the dustcap on and once its down how much weight should i put on it to keep it down? R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
philip Posted February 10, 2009 Report Posted February 10, 2009 yes the 5 min. epoxy is strong enough, but it might get messy if it's the kind you have to mix yourself. i would use ca glue. i usually use about 5 lbs on it after. the fi dust caps are pretty strong. i would also pencil in where you are gonna put it. nothing hurts more than looking at an off centered dust cap and knowing you're the one that put it there.
