well ur subs are single voice coil 4ohm each and you have a 400watt rms monoblock. each 12 is rated at only 150rms so if you wire your subs + to+ and -to- then that would give you a parallel connection and a 2ohm load on the amp and would run each sub with 200 rms which would probably be fine, just make sure to fine tune your gain adjustment and put the subs in a good box. a box makes ALL the difference :D
EDIT: P.S: welcome to the forum chris, im chris  :lol:
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
hey bro. Welcome to the site.. :W:
if you'd like follow this link here: http://www.stevemeadedesigns.com/forums/in...hp?topic=3369.0     read the thread and follow the links and you should have some knowledge on how to set up your amp..
and to answer ur question about comps..i'd say take it 1 step at a time, familiarize your with everything first, read, read, read, and learn.. there's a TON of information in many different forums out there...give your self some time, and eventually you can make that progress towards competitions..
I see Booty
2007 Toyota Camry
19" VMR Rims
H&R Lowering Springs.
Magnaflow Exhaust System
K&N Air Intake
6k HID Projectors & Fogs w/ Black housed headlights.
Optima Yellow Top - Front. Kinetik HC 600 - Trunk
Kenwood KVT-617
Rockford Fosgate 3sixty.2
Rockford Fosgate T2001-BD - Sub Amp
Alpine MRV F-345 - Front stage
Front Stage - A pillars - Dayton Audio 4" mids w/ Vifa Tweeters
Front Doors - Vifa - 6.5" midbass 1" Vifa Tweeters
Subwoofers - 2x 12" Image Dynamics IDMAX - 2.91 cuft ported enclosure tuned at 25hz
oh yeah I do want to take time before I make that step to comps.  Im thinking about buying one thing at time over time til I got the perfect set up.
there's a lot more to it than just buying equipment and slapping it in you're car..just read around and slowly you'll see what i mean
I see Booty
2007 Toyota Camry
19" VMR Rims
K&N Air Intake
Kenwood KVT-617
most of us started with WAY less than what you have man. you wont be disappointed when its all hooked up good.  :watsup:
1- T1000.1bd's
4 runs of 1/0 gauge
-Big 3
All in a CAR.
ok i will.  but is that setup I got a good setup to start with.
sure, if it sounds good to you it's all that matters man...
I see Booty
2007 Toyota Camry
19" VMR Rims
K&N Air Intake
Kenwood KVT-617
