jcro_61 Posted February 15, 2009 Report Posted February 15, 2009 Ok so I have a SAZ3000D,SAX100.2 and will be adding a SAX100.4 later. I have a Powermaster D2400 under the hood and a 250 amp Mechman alt. My question is how much more battery power will I need to run to have as little voltage drop as possible. I wanna stay as close to full power as possible at all times. Should I get a D3100 or 2 or 3? All this is in my Scion TC. I will have trunk space to put some batteries so I don't beleive I will be limited. Also there is some space that if I made a bracket I could run dual alts. Would it be worth it you think to run the stock alt and the Mechman alt? I have a machinist friend who owes me for something, so I could have him make me the bracket. You think its worth it or overkill for my setup? 2015 Chevy Sonic CTX65cs - Image Dynamics 6.5" front CTX65 - Image Dynamics 6.5" rear Rockford Fosgate 3Sixty.3Rockford Fosgate PBR300x4Sundown SAE-600D Sundown SD3-10
Andrew2944r Posted February 15, 2009 Report Posted February 15, 2009 I would start with 1 - 3100 in the back and add more if needed, I really think thats all you will need personally. Team Ampere Audio
jcro_61 Posted February 15, 2009 Author Report Posted February 15, 2009 Cool. Will do. 2015 Chevy Sonic CTX65cs - Image Dynamics 6.5" front CTX65 - Image Dynamics 6.5" rear Rockford Fosgate 3Sixty.3Rockford Fosgate PBR300x4Sundown SAE-600D Sundown SD3-10
Derrick824 Posted February 15, 2009 Report Posted February 15, 2009 You should be good with one d3100 in the back.
