Its looking good, cant wait to see how it turns out.
But I rather be a pro at being myself
Than be an idiot trying to be somebody else
Well, I pulled the rear pillars and deck out so I can get to the stock blose speakers. Pulled them out and did a test fit of the enclosure. The enclosure slid right through the door opening perfectly. However, I need to shave off about 1/4 inch off of the top of the opening I had cut behind the seat. I only need about 1/16th of an inch more, but I have about 1/4" inch of metal to work with so I'll just take that off and had a little extra wiggle room, also once the box is covered, it will probably need that extra space.
97 Maxima SE
Bunch of shit going in, check out the build
looking ill bro
im tuned in
i need ideas for finishing my rear deck =)
mad clean work though, looks like its gonna do some work
Thanks !! One thing I noticed while I had the deck off, the E8's and Tang Band midbass's magnets are hanging down to far for my original plans, I'm gonna have to get creative. Think, think, think......
97 Maxima SE
hmm cant you just glass the rear deck and lift them up some?
http://www.cardomain.com/ride/3042878
TEAM DEADLY HERTZ
"GET LOUD OR DIE TRYIN"only the loudest will survive.
I have to see how my kick panels come out first !!! I've never glassed before so I'll see how I do on those, they are a little more out of sight than the rear deck :) But assuming I do ok on those, glassing something is a good idea.
My original plan was to use 1/4" plywood to replace the masonite piece of crap thats there from the factory and then use MDF rings to raise up the speakers, but that is still not going to give me enough clearance.
97 Maxima SE
i would afford to do the glassing work..BUT i cant access my rear deck? lol
its not hard at all to do..and the rear deck will be 10X easier to do than the kick panels
TEAM DEADLY HERTZ
I'll have an easy starting point. I'm gonna use the existing deck as a template and just run the router around it with a flush trim bit. Boom, new deck, then just build it up from there. I just gotta see the best way to place them, I didn't want speakers taking up the back window as it lowers the WAF (wife acceptance factor). I'll have to see how stealth I can make it.
97 Maxima SE
i gotcha on that one..but if your going to have kick panels in your car your WAF level is pretty high..my ex use to hate mine and passengers would step on them all the time...
TEAM DEADLY HERTZ
I know what you mean about the stepping on part. I'm going to see how I can keep them above foot level if possible. I'm going to try to start those tomorrow so I'll see what I can come up with. Wish me luck, first time glasser !!!
97 Maxima SE
