i have a 97ford probe gt hatchback with 2 18"treo ssx and 2 rd audio 3250.1 strapped @2ohms my best on a termlab was 147.6 my box is tuned to 32hz and is 10cubes 100sqin of port before any displacments this was my first time using a termlab i think my score should be higher oh its subs up port back the score was playing jeezy put on what could help me out and what kind of dbzzzzz should i be getting with this set up
if im right, you only have 10-13sqin of port per cuft, which is kind of low.
every car environment is different, acoustics are a bitch :(
well your tuned low so you wont hit nearly as high as you should say tuning to 38-42 hz and in a hatchback, which has been said a few times in another one of your posts, subs up port up is louder, to a few people.... including my self. 147.6 is a good score tuned at 32 hz but if you switched it to subs up port up, you would prob hit higher
Team_DC-Derrick's Youtube
Team DC Audio
you need to find your vehicles freq,you can do this with a radio shack spl meter at low volume,just do a sweep from say 30-60 hertz and see where it peaks,thatll be you cars resonate freq...meter is like 56.00 bux for the digital,and worth it
07 mote carlo..
deh-p800prs hu-cdt gold 6.5's-cdt 6x9 2 ways-mcintosh mc431m(mids/highs)
bxi2608,2 10w7's in 4rth order(designed by pete k)ported into cabin via armrest cutout
dc power 260 amp alt-missing link module (15.4v)kicker 1/0 kit deka intimidator under hood
metered 141.0 @ 32hz windows down @ kick,termlab
thank for the help guys but i built the box to treos spec maybe i see a new box in my futher but this one does a nise hairtrick tho is there anything i can do to keep it from beating the shit out of my back bumper like maybe some mdf there or something couse 4 layers of dynamat is not helping any
build it the same specs, just change it to port up instead, it can be the same size...
Team DC Audio
under the window, will be the loudest that i have tested... if you check out any of the vids in my car, the port is firing towards the window
Team DC Audio
If your truely going for SPL and don't care about sound quailty then I rebuild your port and tune for around 45 or 50hz, your peak note will a little higher whatever you tune your box at. I seen a two db increase from tuning of 35hz to 58hz, but I am building a removable port so I can have both sql and spl.
ok thanks
