la negra Posted February 20, 2009 Report Share Posted February 20, 2009 i wanted to add a kill switch to my 02 sierra is there a easy way of doing this? i wanted to add the switch somewhere hidden that cuts off the power so it cant be hot wired. and no i dont think ill be posting pixs of this that would make it pointless Quote Link to comment Share on other sites More sharing options...
rusty959 Posted February 20, 2009 Report Share Posted February 20, 2009 well... there are a number of different things you could wire up that wouldn't allow your engine to start/would stop it... you probably have a relay for your coil, probably have one for a fuel pump etc. Quote 2013 Subaru BRZ12" Orion HCCA on AQ 22001967 mustang restoration project: http://www.stevemeadedesigns.com/board/topic/110765-mustang-restoration-build-2011-edition/ Youtube: https://www.youtube.com/user/therusty959 Link to comment Share on other sites More sharing options...
ryde2idie Posted February 20, 2009 Report Share Posted February 20, 2009 a guy brought a durango to my shop and to start the sum bish you had to hold up on the driver control rear window switch. Quote Quote Link to comment Share on other sites More sharing options...
raytard Posted February 21, 2009 Report Share Posted February 21, 2009 so far i've seen a toyota camry where you had to hold the down button on the side view mirror adjust while you crank in order to start, and an acura legend with the same thing, only using the sunroof open button. both of those were basically a relay to the ignition line off of the key cylinder, both were mid 90's simple ass cars the main downside is where you tap it, and how you hide the wires, if its obvious you're screwed either way, and some cars its just a matter of a screwdriver to the starter to get it running hook a relay to the coil and run the switch to something extremely non-obvious, like the clock program button or something, thats probably the best bet, cuz if its to the cylander ignition and they tear the wires out and noitce, its just a few inches of line to trace down Quote Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC Link to comment Share on other sites More sharing options...
Spire Posted February 21, 2009 Report Share Posted February 21, 2009 i would say just a fuel pump switch. but if you really want more thats your choice of course. Quote Link to comment Share on other sites More sharing options...
brewer_brewer Posted March 11, 2009 Report Share Posted March 11, 2009 i used to have an old beater car with busted out windows (we used to jump curbs n shit in it, FUN) didn't want someone to steal it so.... i wired a toggle switch up under the front fender so when i walked by to get in the car i just flipped the switch and it was ready to start. same for when i got out. just flipped the toggle switch back and it wouldn't start. Quote REFS http://www.caraudioclassifieds.org/forum/itrader.php?u=2026 http://www.stevemeadedesigns.com/board/topic/44535-official-brewer-brewer-feedback/page__p__625998__hl__brewer__fromsearch__1entry625998 "you're not allowing natural selection to work, you're like the guy that invented the seatbelt" Link to comment Share on other sites More sharing options...
